It is currently Thu Sep 18, 2025 11:27 pm
PostPosted: Thu Jun 25, 2020 6:41 pm
I’m in the middle of an “Americana” tenor ukulele build for my son-in law. Using only woods from North America. The ukulele has a walnut body and neck and maple binding, bridge and fretboard.
I need some help with the headplate wood. Do any of you have any ideas/suggestions for a darker wood (not walnut) that is preferably burl that I could use for the headplate? I am really running into a brick wall here. It doesn’t have to be as dark as the walnut, but it needs to be dark enough that the gold mother-of-pearl inlay doesn’t look sloppy (It is a thin script). I’m definitely not trying it with maple.
Anyway, any ideas sure would be appreciated.
Formerly know as Mandodiddle.
PostPosted: Thu Jun 25, 2020 7:46 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
One North American wood I can think of that can be quite dark is myrtle. Most myrtle is on the light side, but some pieces can be very dark. If you contact sources that emphasize myrtle they might be able to help you find a head plate piece that's dark.
Oregon Wild Wood: https://tonewood.com/guitar-tonewood.html
Pacific Coast Woods: http://www.pacificcoastwoods.net/
Is it practical to stain a lighter wood dark and then inlay? Or maybe inlay the wood first and then stain it dark?
PostPosted: Thu Jun 25, 2020 8:32 pm
Texas Ebony is pretty dark. Its tough to find large pieces but maybe you could do a multi piece headplate.
Another wood that's darkish is Persimmon. However it is very hard and is alot like African ebony
If you want a practical route. Holly wood stains amazingly well and can take a perfectly black stain with great results.
PostPosted: Thu Jun 25, 2020 8:47 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Desert ironwood, quite dark, but miserable to work.
B
PostPosted: Thu Jun 25, 2020 10:22 pm
If you want burl, redwood burl can always be located. I do not know if "Russian Olive" is native, but when a neighbor cut one down, it was dark inside. If you can find an old, sick Red bud (so you can cut it down), it is dark inside.
PostPosted: Thu Jun 25, 2020 10:27 pm
First name: Daniel
Last Name: Oates
City: Sharon
State: Connecticut
Zip/Postal Code: 06069
Black locust can be oxidized to look black. The sample on top is black locust. The sample below is Gaboon ebony.
PostPosted: Thu Jun 25, 2020 10:33 pm
"I’m definitely not trying it with maple."
Maple heartwood is fairly dark.
PostPosted: Fri Jun 26, 2020 1:06 am
Last Name: Kincheloe
Gold MOP would look good against redwood burl. Sinker redwood is even darker.
Persimmon is mostly light colored, but it can grow fully black wood. Usually pretty gnarly and thin, but you may be able to find a big enough piece for an ukulele headplate, or at least enough to provide a black background for the logo and have lighter wood elsewhere.
PostPosted: Fri Jun 26, 2020 3:06 am
Curious as to why you don't want walnut if you are using it elsewhere. Mesquite?
Ken Franklin
clumsy yet persistent
These users thanked the author Ken Franklin for the post: gxs (Sat Jun 27, 2020 12:04 am)
PostPosted: Fri Jun 26, 2020 3:48 am
Well I tried to post this before, but I do not see it on my screen, so here goes again.
If your definition of North America includes all the way to Panama, then there are lots of "rosewoods" that are dark,e.g. cocobolo, ziricote. If you want any of those, post your dimensions and I may have some scraps--NC.
PostPosted: Fri Jun 26, 2020 8:07 am
You can ebonize white oak and it will be black.
PostPosted: Fri Jun 26, 2020 10:17 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
You can do the same with walnut too. The iron acetate treatment does not penetrate very far so you will have to do it after sanding everything flush. Test on scrap so you can match the color of whatever filler you’ll be hiding the gaps with.
Bryan Bear PMoMC
PostPosted: Fri Jun 26, 2020 11:22 am
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
Persimmon black an white streaks, ziricote ??
PostPosted: Fri Jun 26, 2020 4:48 pm
You could so the steel wool and vinegar thing on oak
PostPosted: Fri Jun 26, 2020 5:30 pm
Fuming it with ammonia is less messy.
PostPosted: Fri Jun 26, 2020 8:29 pm
Last Name: Howell
City: Atlanta
State: Ga
cherry turns dark red over time. Wipe with lye or set out in sun to speed the process up. Even works through oil finish.
PostPosted: Sat Jun 27, 2020 12:07 am
First name: george
Last Name: s
I was thinking mesquite too. It grows in Texas, AZ, NM, Nevada and C. It can get pretty dark.
PostPosted: Sat Jun 27, 2020 11:16 am
City: Escondido
Zip/Postal Code: 92029
Gibson used holly died black on their headstocks. I assume because it takes die well.
PostPosted: Sat Jun 27, 2020 5:36 pm
Thanks everyone. All great ideas! Now I've got plenty to think about.
This forum is great.
PostPosted: Sat Jun 27, 2020 6:08 pm
First name: Jay
City: Bothell
State: Washington
For those who have combined a staining/fuming/dying/lying/vinegaring wood treatment with inlay, does the darkening method used introduce any issues with doing an inlay? For example, does the darkening effect go deep enough into the wood that you can darken the wood, do the inlay, and then level sand the inlay without worrying about sanding through the dark color into the lighter wood?
PostPosted: Sun Jun 28, 2020 11:12 am
Holly dyed black often looks like the best ebony.
PostPosted: Sun Jun 28, 2020 11:42 am
Fuming with ammonia works differently with different woods. With porous woods, such as oak, black locust, and osage, the color tends to go all the way through, but it may not with something that's tighter grained. This is one of those places where the old finishers rule of 'try it on scrap first' is essential.
A former student sent me some 'soft shell almond' wood that he got in a fire wood pile in California. It's very hard and tight grained, with a grain that looks lot like cherry, but it's darker and not as red. 'Mountain mahogany' would be another good one, if you can find some. I've got some wood from a plum tree that's also tight grained and quite dark.
PostPosted: Sat Jul 04, 2020 3:23 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
You can darken cherry with UV or a solution of potassium dichromate. That can be done after the inlay. There is cherry burl, though it may be hard to find. Hampton Brothers Guitars recently acquired some, but I don't know about the size or quality.
You should be able to find Texas ebony that is large enough. I have cut many guitar bridge blanks from it.
PostPosted: Sat Jul 04, 2020 7:38 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
Generally speaking, ebonizing treatments (i.e. using a chemical to make a wood that is not ebony look as black as ebony) have a very superficial effect. The depth depends on the hardness and porosity of the wood but it is usually less that 1mm. Therefore, it is very easy to sand through the black layer. In a large piece (I recently ebonized an entire neck) you can just retreat the sanded area and it will darken again. But if it was an inlay you would risk darkening the surrounding timber, which would make a mess
